Old Jun 17, 2014 | 02:34 PM
onehundred80
Default Re: Cooling system fan question
Originally Posted by Avantidude
Bill that helps, because mine, if I turn the ignition on, then hit the ac button the blower fan operates at whatever speed it is set at, and wait a few seconds, the radiator fan comes on slow about 10 sec, the shuts off. After twenty seconds comes back on for 10 seconds, and repeats this cycle.
If I was you I would put a voltage meter on the fan plug and see if the voltage is fluctuating. At least that should tell you which side of the plug has the fault.
