Old Jun 28, 2014 | 12:07 AM
  #713 (permalink)
MRGR3YXF's Avatar
MRGR3YXF
Default Re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Pizzaman- Thanks for answering my questions.
Just one more quick question, If I am able to push the pin in and remove the ignition switch from the steering column, In your opinion do you think I will be able to grind the end of switch down, which would enable me to release the "locked position"? The pin does push in for some reason?!
Thanks..sorry for the silly question.
