Mrmiata
I know I could spend the day with search and put my answer together.. but thought I'd throw this out and see if I can get a faster response..
Would these fit okay without spacers and clearance issues?
Front
• Size: 19x8, 32mm Offset
Rear
• Size: 19x9.5, 32mm Offset
Fronts will fit fine; rears will also fit, but will sit deeper inside the fender by 8-10mm each side (vs factory).
Not necessarily a deal breaker, but if you're running 19's up front, I'd try to find a suitable 20" wheel in the rear with approximately +25mm offset.
