Wheels ... again...
Old Jun 28, 2014 | 06:40 PM
Mrmiata's Avatar
Default Wheels ... again...
I know I could spend the day with search and put my answer together.. but thought I'd throw this out and see if I can get a faster response..
Would these fit okay without spacers and clearance issues?
Front
• Size: 19x8, 32mm Offset
Rear
• Size: 19x9.5, 32mm Offset
Old Jun 28, 2014 | 07:12 PM
xme's Avatar
xme
Default Re: Whees ... again..
I bookmarked this for myself... But it appears the answer is yes
https://www.crossfireforum.org/forum...hat-works.html
Old Jun 28, 2014 | 07:40 PM
Mrmiata's Avatar
Thanks for the link! Might have to look into 20's for the rear to help keep the "factory look"..
Old Jun 29, 2014 | 12:18 AM
Beaner's Avatar
Default Re: Wheels ... again...
fit = yes
look wrong in the rear = yes
your decision =yes
Old Jun 29, 2014 | 01:01 AM
JHM2K's Avatar
Front
Rear
Fronts will fit fine; rears will also fit, but will sit deeper inside the fender by 8-10mm each side (vs factory).
Not necessarily a deal breaker, but if you're running 19's up front, I'd try to find a suitable 20" wheel in the rear with approximately +25mm offset.
Old Jun 29, 2014 | 11:58 AM
Mrmiata's Avatar
Originally Posted by Beaner
fit = yes
your decision =yes
Is my math not working right.. ? The extra offset puts it about 3/8 more under the car.. the extra width over stock puts it 1/8 closer to wheel fender.. right?
Me and metric ain't best buds.. LOL
So look wrong? Or do you mean from being a 19 all the way around..
Old Jun 29, 2014 | 12:02 PM
Mrmiata's Avatar
Just doing a "fast look" when I go to 20" I'm pulling up 8 1/2" width.. not going to happen there.. This find wheels for your wife is a whole bunch of fun.. LOL.
Old Jun 29, 2014 | 12:59 PM
xme's Avatar
xme
So look wrong? Or do you mean from being a 19 all the way around...
That's what I came up with too. Although that doesn't necessarily make it right either
I think Rob at Needswings had access to some staggered 18/19s too if you aren't set on 19s in the front. A couple of styles of AMG replicas if memory serves.
Old Jun 29, 2014 | 01:04 PM
Mrmiata's Avatar
closer to stock works for me.. these are what she has decided on.. for the most part.. LOL
Old Jun 29, 2014 | 03:43 PM
Me like.
If you get them and the missus don't like them, give them to me.
Old Jun 29, 2014 | 04:22 PM
Mrmiata's Avatar
Me like.
We'll have to see how they look on an Alabaster Coupe first..
And thanks for the fix on the thread title Mr. Moderator..
Old Jun 29, 2014 | 04:56 PM
Mrmiata's Avatar
Nice little online tool here..
Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
Old Jun 29, 2014 | 05:06 PM
cg80's Avatar
Greg: I really like the looks of those Rims...are they very expensive...what type are you/Sherri considering, the gloss black or the machine faced...Carl
Old Jun 29, 2014 | 05:11 PM
Mrmiata's Avatar
They should come in under a grand for the set. And she likes the ones just like in the video.
Old Jun 30, 2014 | 05:59 PM
HOT FIYA's Avatar
www.willtheyfit.com
You're welcome
Old Jun 30, 2014 | 07:18 PM
Speedy4x4's Avatar
What tires sizes are you running?
Stock or wider rears?
I ask cause on my research since you are thinking about stepping up to a 19/20 there are ALOT more wheel options with 10-10.5 rears.
And more options on rotoformed wheels.
A 19x10.5 5x112 will cost $768 apiece unless rear hubs are "fill in drill" to a 114.3 then just a 73 to 66 hub spacer (which you will probably need anyway)
Old Jun 30, 2014 | 07:30 PM
Mrmiata's Avatar
Currently just the stock set up. These that she likes start at 19".. so..These are what I've found (haven't researched best price yet). Unless a 20 x 10 40mm for the rear will fit.. No spacers just center bore adapters.
Lorenzo WL27
Front • Size: 19x8, 32mm Offset - Front: 255/30ZR19
• Price: $228 (each)
• Est. Availability: In Stock
• Weight: 32.2lbs.
Rear • Size: 19x9.5, 32mm Offset - Rear: 255/35ZR19
• Price: $232 (each)
• Est. Availability: Fewer than 3, Special Order Available
• Weight: 32.7lbs.
Old Jun 30, 2014 | 08:06 PM
Mrmiata's Avatar
Originally Posted by HOT FIYA
www.willtheyfit.com
You're welcome
Thank you for the contribution.. looks like my find above yours gives a little more in detail. Both say need at least and inch from the suspension over stock..
Old Jun 30, 2014 | 08:44 PM
Speedy4x4's Avatar
Lorenzo WL27
• Weight: 32.2lbs.
• Weight: 32.7lbs.
There website says 19X8 / 20x8.5
255/30 19th on front isn'the that to wide?
You like black&chrome with lip best?
Or concave, flat?
Silver, gunmetal etc.?
Does weight of wheel matter to you?the metal bore adapters r cheap on ebay
http://www.lorenzowheels.com/wheels/WL27/WL0273?year=2004&make=Chrysler&model=Crossfire
Old Jun 30, 2014 | 09:50 PM
Mrmiata's Avatar
That was just the size tire one website listed for it.. She likes the black / chrome with the "rivet" design on the edge.. and several spoke design.. but she wants "flair" with it.. not just plain spoked.. now I know why they take so long to shop.. LOL. Found this .. it's where I'm pulling my available sizes from. Not real concerned on wheel weight.
Lorenzo WL27 Glossy Black w/ Machined Face Wheels & Rims | Belle Tire
