Need some sage advice... what to do?
Jul 9, 2014 | 10:07 AM
40
permalink
Padgett
Oct 2013
2,152
37
Orlando
Re: Need some sage advice... what to do?
OK fols, there hane been several threads in the past on Torque Pro & the TorqueScan plugin (both available from the Play Store) and OBD-II dongles (I have a Mini to maximise knee room like
this
Use the TorqueScan plugin to find what parameters the XF supports. (Note it does identify itself as a Chrysler and not a MB) then add to the RealTimedisplay.
You can try using the enclosed torquedial.dat file I use on my phone's 3.5" display. With a 8" tablet I can put all on the same page.
Note: I had to rename torquedial.dat to torquedial.txt to add as an attachment. Change back to .dat and copy into the .torque directory (may need to enable hidden files to see the directory).
I check for fault codes & run the full test sequence occasionally to see what is happening but usually run in realtime mode.
ps can run it and play music or run the sat-nav at the same time but shut down completely when not in car to keep it from draining power.
torqueDial.txt
Padgett
View Public Profile
Send a private message to Padgett
Visit Padgett's homepage!
Find all posts by Padgett
