ala_xfire
Yes, I see that now ! BUMMER ! Will the 6 cyl one fit the same ?
Yep, see the " 112 " as the start of the part number on the water pump? Look right below that and you'll see the number for the timing cover.
The only difference is the length and extended components for the 2 extra cylinders. Other than that, I can use anything from the V6 pretty much.
