deerhunter
Thanks for the reply. I am going purchase a new metric set today, maybe I am just missing
the one I need. Also, once I get the door handle off, does that little piece that is attached to the
car, does that come off also without having remove the door panel to access any screws behind it?
Sounds as if you had yours off before? And the little screw on the bottom side of the door handle
the one you see when you pull the handle out, do you have any ideas as to what size it is? I presume it
is metric also?
Thanks
