Old Jul 26, 2014 | 11:30 AM
onehundred80
Default Re: alright guys fuel injector question
Originally Posted by crossmember
i just ordered some 19 lb fuel injectors because the stock ones are 17lb so i thought i would give her a little more at wot anyways my question is when i remove the fuel rail i read in the service manual it says there are fuel injector retaining clips but it looks as if they retain the injectors to the fuel rail and not the engine so if that is the case i can just pull up on the fuel rail after i remove the bolt correct?
You have an NA. They are overkill I would have thought. Save your money.
