SrWilliams
Mr M:
Thanks so much for your reply. When i posted I had a feeling that if you saw me in distress (as I am always in) you would chime in. Again, thanks so much. I had been using a clothes hanger and I was digging from the inside but I could not find a thruway. Is the hole from the inside above where the stock amp is or closer to the left door side. I want to go back digging with the hanger but I need an idea as to where to find the gap
It's not easy to locate from the inside.. but about the center line of the battery and 2-3" down lower than the bottom of the battery.. so basically "transfer" that to where you are inside the car. Your going to be off towards the door side of things under there..
