Charles.vanover
Also I'm not using a Bosch crank position sensor and the car is running like a dream
I'm glad it is all worked out. I was going to say that it is usually a simple fix, too many start fiddling with the wiring, which for the most part doesn't just go bad. No moving parts but corrosion can be a problem, especially in coastal areas.
