Old Mar 6, 2004 | 07:19 AM
WesMichaels's Avatar
WesMichaels
Default
Originally Posted by AZ Outlaws
WMichaels,
Great!!! Can you pass on the P/N etc? I believe you said you ordered them through Tire Rack?
Yep... Tire Rack is the place and the P/N for the fronts is... "DP21075" I haven't done the rears yet. I wanted to see if I liked them on the front before I put them all the way around. At first I was affraid that having 2 different brake componds might upset the bias. But it doesn't. The car stops even better than before. With the stock pads, every now and then when coming to a slow stop you could feel a slight (nothing drastic) pull to one side or the other. Now I can let go of the wheel and she stops perfectly straight. The feel is much, much better. I Highly recommend.
