Old Aug 13, 2014 | 09:17 AM
Padgett's Avatar
Padgett
Default Re: 2006 Crossfire Won't Start
Classic "cranks but does not run". First thing I usually do is triage: pour about 1/2 ounce of fuel directly into the intake, button up, and try to start. If it runs then dies it is a fuel problem. If nada then probably a spark issue. (weasle words: have a good fire extinguisher handy.)
Once that is done I pull out the right set of gauges.
Have only three possibilities: fuel, fire, mechanical & of the three, a mechanical failure without sound effects is the least likely. (Crank sensor is an electrical problem)
