Old Aug 13, 2014 | 08:49 PM
  #63 (permalink)
onehundred80
Default Re: Ignition key won't turn
Originally Posted by AirdrieXFire
Hey Ron,
Any idea why the key would turn after this but have not detents? As mentioned above, it turns after removing the "hidden pin" but only from Off to Start and back while not starting the car in the start position...
Thanks!
The tumblers are inside the lock cylinder. The cylinder should be OK unless you have played around with it.
Frankly I am a bit lost with your description.
Use the words in the PDF and we will understand better.
You say the key springs back to the OFF position from the start position, it normally springs back to the ON position from the start position.
I'm wondering if you have connected the interlock cable correctly. I am not sure if the detents are actually in the lock cylinder, they may be caused by the cable.
