Old Aug 15, 2014 | 08:55 AM
Indelibility's Avatar
Indelibility
Default Re: Problems since changing the battery
Originally Posted by colinrich
I didn't see if they tested it while still in the car as they couldn't look at it straight away so I left it with them and when I returned it had been replaced.
Everything else seems to work except the cigarette lighter but I had never used that so it may never have worked.
I looked through the manual and cannot find which fuse controls the low rad dash light so I guess the best thing to do today is pull all the fuses and check.
4 things:
1. Make sure the sensor is connected to the bottom of the coolant reservoir tank.
2. Check to see if the radiator fan is plugged in.
3. Check the fan control module, the plug can become lose.
4. Make sure your coolant temp sensor is plugged in, it's located next to the thermostat.
All these can set off your coolant light.
