Old Aug 15, 2014 | 01:34 PM
onehundred80
Default Re: Problems since changing the battery
Originally Posted by colinrich
Have checked all the connections as suggested and all ok as are all the fuses, thanks for the tips.
Will have to wait until my return on Monday to the garage to see what they come up with.
Have also noticed that the battery is loosely fitted and I can rock it around and despite the negative connection to the battery being at its tightest I can still pull it off by hand meaning the terminal on the new battery must be smaller than the one its replaced.
You need to take of the terminal, unscrew the bolt five or six turns and open up the terminal, by using a screwdriver in the slot. The terminal will then sit lower on the taper of the battery terminal and will clamp up as it should.
