Old Aug 23, 2014 | 11:56 AM
  #735 (permalink)
onehundred80
Default Re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Originally Posted by hXchandler
I apologize if this has already been explained but I couldn't find an answer. My 04 started getting the sticky key issue about 2 months ago, I read up on but was minor and I hadn't gotten around to fixing it. Last week it started bothering me, taking 4+ times to start, so yesterday I finally did the fix only to find that it had already been done on this car. I bought it used 2 years ago and it is a one owner car according to carfax. Talked to the said he had no clue what I was talking about. I have a spare key Chrylser cut recently and neither key works. Any clue why it wouldn't turn after this mod? Appreciate all the info you guys share here.
Are you really sure you did the mod properly? Did you remove the little cover and find no spring and pin under it?
It is possible that the interlock on the transmission is not set properly. If you jiggle the shifter does it make any difference when turning the key?
