Old Aug 26, 2014 | 11:26 AM
  #738 (permalink)
ijaved's Avatar
ijaved
Default Re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Originally Posted by hXchandler
I didn't do the mod I took the assembly off and found that it was already done by a previous owner. The little cover was missing, haven't check wiggling the shifter but I will after work
If owner said he didn't then try to look for the little cover inside.. maybe it fell inside and that's what stopping it from turning. try vacuum. Also some said spraying WD-40 in the cylinder helps? I don't know how safe is that.
