Old Aug 27, 2014 | 09:34 PM
ala_xfire
Default Re: Adjust/aim headlights
The white **** on the back of each unit should raise and lower them.
Be aware that you can overdo it and the adjustment screw will pop out of the socket.
Before using these adjustment ***** however, ensure all the H7 bulbs are properly seated
with the little extension on the bulb in the notch.
You can use a small mirror and a flashlight to check this.
