Thread: fusebox nut
Old Sep 4, 2014 | 08:31 PM
JEFASOLD's Avatar
JEFASOLD
Default Re: fusebox nut
[QUOTE=blackpepper;810836]I did the coolant pump always on mod,and yes I dropped and lost that small nut,the one that require a 7mm socket to remove anymore know the size so I can run out to lowes and get another?
Did you drop it in the engine bay? If so, it's not lost, just go to the local hardware store and get an extendable magnet tool, then fish around. Usually it will drop all the way down to the pan beneath the engine and thats easy to take off, just four 8mm nuts and one 10mm nut. Good luck.
