fusebox nut
Old Sep 4, 2014 | 05:11 PM
blackpepper's Avatar
Default fusebox nut
I did the coolant pump always on mod,and yes I dropped and lost that small nut,the one that require a 7mm socket to remove anymore know the size so I can run out to lowes and get another.
Old Sep 4, 2014 | 08:31 PM
JEFASOLD's Avatar
Default Re: fusebox nut
[QUOTE=blackpepper;810836]I did the coolant pump always on mod,and yes I dropped and lost that small nut,the one that require a 7mm socket to remove anymore know the size so I can run out to lowes and get another?
Did you drop it in the engine bay? If so, it's not lost, just go to the local hardware store and get an extendable magnet tool, then fish around. Usually it will drop all the way down to the pan beneath the engine and thats easy to take off, just four 8mm nuts and one 10mm nut. Good luck.
Old Sep 4, 2014 | 10:56 PM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
If you dropped it into the fuse/relay panel compartment, disconnect the battery before probing with the extension magnet. And you do want to be sure to find it if it is still in there !!!
syfi
Mar 28, 2026 04:14 PM
gp1200x
Dec 6, 2015 12:59 PM
frogwash
Aug 14, 2015 03:44 PM
Boresite
Aug 9, 2015 10:33 AM
Franc Rauscher
Jul 31, 2015 01:12 PM
