Old Sep 8, 2014 | 12:46 AM
  #741 (permalink)
hXchandler's Avatar
hXchandler
Default Re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Mine wouldn't even turn to the first position but either way this should be done ASAP while you can still drive it into the garage..
On an unrelated note I was never able to get this to work properly, after the mod the key would turn with no problems but as soon as I installed it locked up worse than before. Ended up taking out the cylinder so the plunger recessed, installing, then driving a bolt through where the pin used to be. Works fine now but the steering wheel doesn't lock anymore, anyone got some insight on what could have been the problem?
