Re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Ok, my key would only turn once in about 200 tries, fortunately I got it out without drilling, did the fix and removed the black ring around the key, but then the key acted up again, and I couldn't get the key mechanism out of the housing. I took the housing to a lock smith today and he finally got it to turn again and got it out of the housing. He is going to cut a new key (mine looked totally worn out - and it broke off the little key bob too) in the morning. I'm hoping with a new key, the mech might start to work better, if not, I assume I will need to buy a new mech to use in the original (now fixed) housing. If so, does anyone have a good source for it and can they key it to match your original key.
Also can you get new keys for these guys with the key bob? My seller only had the one key and it's in pretty sorry shape.
Thanks,
Dave
