Old Sep 15, 2014 | 05:06 PM
onehundred80
Default Re: Various lights not turning off!
Originally Posted by power90801
So while troubleshooting my Central Locking Pump today I pulled fuses 25 and 26 to swap them and see if my 26 fuse was bad which might explain why I have no locks. The pump is exposed mind you but does not run, no sign of water, looks brand new, wanted to check the fuse basically. Strangely now there are several lights that will not turn off unless I pull both 25 and 26 again. They are the following:
Fog lights
side indicators front and rear
small white indicator upper corner of headlight assembly
Tail lights
What could I possibly have done by pulling those 2 fuses? Is the CL pump tied in to the lights in some way? I'm not sure where to begin.
Yes the CL pump module has input into the light circuits as you have found. You can open up the module and see what is going wrong.
