Old Oct 1, 2014 | 10:41 AM
boostmonkey's Avatar
boostmonkey
Default Re: Axle stand points
You start by jacking up the rear by placing the floor jack under the differential, this will allow you to raise high enough to get 2 fully collapsed jack stands under the 2 rear jack pads.
Then move the jack to the front where you will find a cross member just behind the engine.
This will allow you to raise the front enough for the other 2 jack stands under the front 2 jack points.
If you jack up the rear first, there may not be enough clearance to get your jack underneath the nocse. I recommend doing the front first if using this method.
