Valve Cover Leak and Torque
I replaced my valve cover gaskets because I had a small leak at the rear cylinders from the original gaskets. After driving for a while, just noticed it is leaking again slightly on at least one side. I torqued to the factory spec (can't recall, but I think about 8 ft lbs) and used lock tight.
Are others experiencing this issue? Anyone tried tightening them a bit more, how much more, and any good results?
