Old Oct 5, 2014 | 10:52 PM
JEFASOLD's Avatar
JEFASOLD
Default Re: Trunk stoppers causing damage
Originally Posted by nickwe21
Hey guys!
Never really realized this but the rubber trunk stoppers are leaving deep marks on the frame of the body around the trunk. I already have a little rust there probably caused by the nice and salty Florida air. Any suggestions? How do I get the rust off? Figured take the rust off, touch the area up with matching paint and then maybe put something there to protect it. But what? If I just put tape there it would probably look pretty silly.
Do you guys have these issues? Thanks for your help!
You need to adjust the rubber bumpers, they should not be doing damage. Loosen the bolts, then adjust the bumper so that the hatch closes securely but doesn't hit the body. There is a range of adjustment, if done correctly it should just leave a slight mark where it seats but no dents or damage. Hint, both sides should be just about the same.
