hXchandler
On an unrelated note I was never able to get this to work properly, after the mod the key would turn with no problems but as soon as I installed it locked up worse than before. Ended up taking out the cylinder so the plunger recessed, installing, then driving a bolt through where the pin used to be. Works fine now but the steering wheel doesn't lock anymore, anyone got some insight on what could have been the problem?
I don't recall seeing this before. Just to be clear, you took the pin and spring out from under the housing cover you had to distort/pound/center punch the cover to get off? But then you drove a bolt back in where this pin was? If I am reading correctly the stationary bolt is now in a place where there used to be a spring tensioned pin, if so then things would act flaky. Did you take pics?
