Old Oct 11, 2014 | 01:49 AM
clok1966's Avatar
clok1966
Default Re: Dash maintenance Icon question
Originally Posted by nickwe21
If I recall correctly if the number is positive it means "miles till next service". If it is a negative number it means the amount of miles that have past since the service should have been performed. So if you see the little wrenches (1 or 2) and it says -12000 that means your service A or B depending on the wrenches has been due for 12000 miles. Now of course this is not necessarily cause for concern as there might have been a service done if you have documentation but the shop forgot to reset the light!
What is the fan you speak about? The secondary air injection pump? Do you get check engine error code P0410?
Sorry the fan (heat/AC) no air movement , not running, there are many thread on the resistor failing, but most say it works sometimes. Mine never works, I have pulled the fan and resistor and ordered the resistor. I was just wondering if the resistor dies completely and it wont spin at all.
