Old Oct 11, 2014 | 11:26 PM
chrisificti0n's Avatar
chrisificti0n
Default Clutch pedal position switch
Hi all -
I'm hooking up a remote starter (keyless) and I need to wire in so that it will only start if the clutch is depressed.
The clutch has two switches.. one that is engaged when you push the clutch in and one that is engaged when you don't push the clutch in.
No matter what I do, I cannot get a signal from the switch. Anyone got a recommendation?
