Old Oct 21, 2014 | 07:29 PM
nickwe21's Avatar
nickwe21
Default Re: exterior door handle removal EASY 2 screws
Originally Posted by ITF36059
If it is the interior door pull you are referring to, you do not need to remove the door panel. the door pull is a 2 piece assembly. Carefully remove the out shell and this gives your access to the two screws holing the inner shell. the 2 screws are TORX heads. remove them and pull the handle out. You got off cheep if you broke the passenger side. The driver's side pull cost me almost 300 dollars.
Good Luck.
Mike
My driver side door pull broke off a while back and it cost me about $5!
There is an amazing DIY fix on here that fixes the door handle and makes it 10 times more durable while looking 100% stock. You would never even guess there was something done to it! It is always a good idea to use the search function before forging over lots of money.
