HellKat
I have a 2005 limited that I bought used with 93K miles on it. LOVE my car but about 4 months ago I tried to start it and nothing
. Thought it was an I isolated incident but I was wrong
. Now she won't start at all....all lights, radio, etc work but the engine will not even crank..starter does not even click
. I have a crankshaft sensor on order but was wondering if it could be a clutch switch. Has anyone replaced the clutch switch? I also checked the RCM and the solder points look great!! Any help would be greatly appreciated!! Miss driving my baby!!
With "not even a click".. your CPS should just be kept as a spare. You don't have a white cased battery sitting in there do you? My "new" 06 roadster has the white OEM Varta.. knew it was going to need replaced very soon. Spoiler raised up the other day after starting to confirm this. Check those connections and trace ground wire to chassis and make sure it's got good contact.
RCM - "Looks Great".. was that under magnification? Most "look great" to the naked eye.
