Re: Left side dome light issues
I took my assembly apart & found that the bulb socket assembly was not fully seated on the two power runners. This was giving intermittent contact. Make sure the contacts on the bulb socket assembly are making good contact with the power rails. The socket assembly requires a quarter turn. The rails could also be secured by melting some styrene plastic where the plastic pins protrude thru the holes in the runners.
Stan
