Old Oct 29, 2014 | 08:02 AM
Valk
Default
Before you start splicing / relaying, consider that the 2 are joined at the hip internally. There is only one adjustment, if you adjust so that the hi beam is lower ( like the low beam ), then the low beams will be pointing almost at the ground.
Very good point
