converting hi-beams into low beams?
Old Oct 28, 2014 | 08:52 PM
rmcdaniel12's Avatar
Default converting hi-beams into low beams?
Wondering if there is anyone out there that has converted their hi-beams into low beams to be used as quad (4) headlights? I think it would look pretty decent at night having 4 HiD headlights on. Let me say that i literally never use my high beams before anyone jumps to conslusions. I have 2 crossfires so i dont mind playing with one. Just stick with my topic. Im thinking that i just cant splice into the low beam harness as it may cut the voltage in half. Im leaning towards possibly having to add a relay and branch off of there.
Old Oct 29, 2014 | 07:55 AM
Default Re: converting hi-beams into low beams?
Before you start splicing / relaying, consider that the 2 are joined at the hip internally.
There is only one adjustment, if you adjust so that the hi beam is lower ( like the low beam ), then the low beams
will be pointing almost at the ground.
Old Oct 29, 2014 | 08:02 AM
Default
Before you start splicing / relaying, consider that the 2 are joined at the hip internally. There is only one adjustment, if you adjust so that the hi beam is lower ( like the low beam ), then the low beams will be pointing almost at the ground.
Very good point
Old Oct 29, 2014 | 08:43 AM
Thanks guys. Didnt even get as far as checking for a secondary adjustment. Guess thats why it hasnt been done yet.
Old Oct 31, 2014 | 01:30 AM
Adrian_X's Avatar
Actually, if I'm not mistaken the high beams do have their own adjustment ****. I think it's hidden and can be adjusted with a flathead screw driver. I forgot who said they found it on the back of the headlight unit, but yeah. Just a thought.
Old Oct 31, 2014 | 07:06 AM
Red Dog gave me a pair of old headlights that had smashed lenses, so I dissected one.
I can assure you there is only one up-down adjustment for both lights.
The flat head screwdriver looking things are capped factory adjustments for left/right, and yes there is one for each light.
Old Nov 1, 2014 | 03:38 PM
Adrian_X's Avatar
Ah ok, so it was only for horizontal movement then. Makes sense lol
syfi
Mar 28, 2026 04:14 PM
Osusannah
Feb 12, 2024 01:49 PM
Darryl Camisa
Oct 7, 2015 07:10 AM
DaveMe
U.K.
Sep 29, 2015 08:09 AM
