Old Nov 2, 2014 | 11:37 AM
dedwards0323
Default Re: Oil level Indicator higher than normal ?
Originally Posted by oledoc2u
Ok, I guess I am missing something. If you drain every bit of oil out of the engine, it will take 8 1/2 quarts to bring it back to level. I still drain mine the old fashion way. I let it drip after I warm the engine for a good half hour. The gauges shown is fuel and temp, so where did the oil level come into the equation?
Originator of this thread thought the engine temp gauge was oil level indicator. Just some confusion in the beginning. No big deal.
And yes, the M-B spec calls for 8 LITERS of oil for an oil change. That is essentially 8.5 QUARTS of oil. I just mentioned that quite a few XFire Owners simply add 8 quarts w/o any issues. Saves having a 1/2 quart of oil stored in the garage (MHO).
And like you, I drain the oil from the pan underneath rather than siphon the oil out using a pump. Running the engine for 20-30 minutes is a good practice as the oil will drain much easier from a warm engine compared to a cold engine.
