oledoc2u
If the car cranks BUT will not start, that is usually a Crankshaft Position Sensor that has gone bad. An under $50 part that you can replace yourself. IF you turn the key and there is NO cranking, that is a Relay Control Module problem, and again this can be fixed usually with a little soldering. There are "how to's" on these repairs.....
It seems to crank, all electronics work and all lights come on. Where should I buy the part? I've had problems in the past of buying a part that doesn't fit.
