Old Nov 8, 2014 | 03:49 PM
Mrmiata's Avatar
Mrmiata
Default Re: Headlights - Low Beam
LOL... it's doable.. but here's a note.. You can pull the headlight relatively easy.. pop side marker out.. you can see that lower bolt.. remove top two "obvious" bolts.. reach around and under the headlight from engine bay and you will find #4 bolt that you can work a little and get out. Take top bolt out from Facia next to headlight.. Pressing down on the bumber cover just below the headlight you can get it pulled out.. Just did this to remove silicon sealed bulb mess! There are a couple headlight vids on facebook page..
