Old Nov 26, 2014 | 08:38 AM
ala_xfire
Default Re: Camshaft position sensor: DIY replacement with pics
Check the CPS connector, scratch up the 2 contacts with something and see if that fixes it.
Use some dialectric grease to prevent further corrosion.
You should be able to meter the sensor, should be real close to 0 ohms as it is nothing but wire wrapped around a magnet.
My first exposure to these was back in the early 70's when they were on a high speed card punch I used to maintain. They were called "reluctance head pickups" back then.
I used one of those on my modified Yamaha flat track bike in a total loss ignition system to trigger a power transistor. It was mounted next to a circular plate on the crankshaft that I had cut one 1/4" notch in. Worked flawlessly.
The CAMSHAFT sensor on the other hand is a "Hall Effect" sensor. In layman's terms, it is a transistor that is excited by a magnet in the camshaft as it passes by causing it to conduct.
These were also used in older computer keyboards made by Cherry. ( no key bounce due to dirty contacts. )
This was back in the day before throw-away keyboards.
