Thread: rear subs
Old Dec 6, 2014 | 12:28 PM
mobilefitt's Avatar
mobilefitt
Default Re: rear subs
Originally Posted by Mrmiata
Crossfire audio_diagram.pdf
AMP pin 10 - Right Sub input (+)
AMP pin 9 - Right Sub input (-)
AMP pin 1 - Left Door input (+)
AMP pin 2 - Left Door input (-)
AMP pin 8 - Left Sub input (+)
AMP pin 3 - Left Sub input (-)
This is good info. I am working off the stock amp now. once i get my subs in, I may try to boost the bass with an additional amp or something. The 4 ohm dual coil sub from pyle seems to be doing its job. I have one stock sub and one pyle in place now. I wonder when I swap the other one if the stock amp will produce enough power to push the 300w subs I found on carid.
