Thread: Flasher Hazard
Old Dec 11, 2014 | 10:42 AM
Samuel's Avatar
Samuel
Default Re: Flasher Hazard
Originally Posted by STEPHENJXN
I know this may be redundant...but have you checked all fuses...flasher relays and bulbs?
I checked fuse 4 on the drivers side panel 15a good fuse. Is the relay in the ecm, rcm, etc box....right side engine compartment? That is what has me baffled....I read that the flasher was controlled by an ic in the instrument cluster? After visiting my friend Google, I learned that there is indeed a relay somewhere. Bulls are ok. They do work if I hold in the hazard button
