Old Dec 15, 2014 | 11:53 AM
latemodel21's Avatar
latemodel21
Default Re: the CORRECT SL55 fuel pump p/n please?
Curiously, if you search 2005 SL55 fuel pump (oediscountparts.com in this instance) it gives you both of the pump numbers you mention. Since they are both called out and the price is identical , I suspect the part is as well (likely the newer part supersedes the other). However, if in doubt, I'd buy the 0014706594 which is called out for both the SL55 and SL65.
Cheers,
Chris
FUEL SYSTEM / FUEL SUPPLY / FUEL SUPPLY / FUEL PUMP 0014704994 - fuel pump SL55 AMG
FUEL SYSTEM / FUEL SYSTEM / FUEL SYSTEM COMPONENTS / FUEL PUMP 0014706594 - fuel pump SL55, SL65, SL63
Originally Posted by rmcdaniel12
Can someone clear up a little confusion I have as to which part number is associated with the SL55 fuel pump that is a direct plug and play upgrade for our SRT6's?
I've came across the following alleged p/n's from 2 different sources:
0014704994
AND/OR
0014706594
Someone please clarify which one is correct.
I know Needswings sells a "55 Fuel Pump", but there isn't a p/n in his listing. I like to do research on items from more than one source before I buy. I don't want to waste my time researching the wrong p/n.
Thanks in advance XF Fam!
