Re: the CORRECT SL55 fuel pump p/n please?
rmcdaniel12
Can someone clear up a little confusion I have as to which part number is associated with the SL55 fuel pump that is a direct plug and play upgrade for our SRT6's?
I've came across the following alleged p/n's from 2 different sources:
0014704994
AND/OR
0014706594
Someone please clarify which one is correct.
I know Needswings sells a "55 Fuel Pump", but there isn't a p/n in his listing. I like to do research on items from more than one source before I buy. I don't want to waste my time researching the wrong p/n.
Thanks in advance XF Fam!
I went through this same issue back when I was upgrading the fuel pump on my #1 SRT6 . . . Read through this thread . . . (see post #14 in particular)
https://www.crossfireforum.org/forum...tml#post767802
Now that you are even more confused. I can definitely tell you two things . . . Back at that time I determined that a Pierburg pump part number 7.00228.51 and a Pierburg pump part number #7.28337.00 are both correct for a Mercedes SL55. I can also tell you that the pump Rob at Needswing supplies is a TI Automotive pump with part number A 000 478 21 01 . . . I know because I bought one from Rob and it was still unopened in the box he sent to me . . . I just opened it up to check it out.
