Great advice from Les up there. ^^ Do that.
Reducing the tire pressure a few lbs from the street pressure will likely help. Street tires to not like very low pressures though. I wouldn't go lower than 25 psi.
velociabstract
One thing is for sure, you can't just floor it.
Les
But I can!
The recipe:
Mickey Thompson 255/50/16 ET Street radials, 16 psi, -0.6 degrees rear camber, 0.1* rear toe-in, Wavetrac diff, well prepped track, 1500 RPM brake stall, then: WOT. No wheel spin. 1.7 60 times.
Oh, and a short burn out. Not too long. The tires get greasy if they get too hot.
