gerry44
I got the caps and will put them in (cheap fix) if it works man at radio shack said it should also. I will do this before I go out and buy a new radio Again mine is a coupe so there are no rear speakers just in the door which is where I will put the caps on the black wire like post 21 says.
"Base" models were the only ones without the subs.. Coupe's that are Limited or SRT6 have subs.. haven't looked for what you have.. but ALL 04 models are "Limited" models since base versions came out in 05 I believe it was. Move your seat forward and look behind them for the subs in the divider wall.
