Old Dec 27, 2014 | 10:12 PM
pizzaguy
Default Re: instructions on replacing a blown rear brake light on convertable
Originally Posted by figgy7935
someone else had suggested the opening of the top. They mentioned you only have 10 mins before the toneau cover comes down. Worried about that damaging the cover
I use my hiking "trekking pole" (which is a telescopic walking stick that can lock in any length).
Use it to prop the cover up. The window will also relax, don't worry about it. Use techniques from the manual procedure to return the top to all-the-way-up or all-the-way-down if you need to.
