Re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Got the same problem. Key won't turn out of 0 position. Got everything open. Can I just grind out shiny pin, remove lock Assembly and fix or will I need new Assembly? Also cannot see the photos so working a little by guess work. PS. LOCK ASSEMBLY WILL ROCK BUT PIN STILL IN WAY AND KEY WILL TURN MAYBE 5 mm but won't reack position 1
