Old Dec 28, 2014 | 10:16 AM
onehundred80
Default Re: Supercharger not working-suggestions?
Originally Posted by Sweet2002
The SC will not work with the stock or performance tune. I may have seen a code for a weak o2 signal for one bank. I can try to see if a reader shows it still. Wish I understood electronics. Dumb question, how do I go about testing for 12volts and for ground or would I not see ground at idle? Still a little more help guys. thanks for getting this going.
Now you mention it not working with the stock tune, when did you try it with the stock tune?
Did you go back to the stock tune after the SC did not work with the modified tune?
How long did you run it without the modified tune?
Does the pulley look OK with the correct gap or is the gap too large?
Maybe the electromagnet has got too hot from slipping and burnt out.
I'd take the pulley off and look at the magnet.
Is the clutch plate still attached to the pulley?
I am clutching at straws here.
