Old Jan 7, 2015 | 12:05 PM
Sweet2002's Avatar
Default Eurocharged datalogging
First please excuse the caps, i can barely read the small print that this site gives. I am looking for information on datalogging with the eurocharged software that comes with their performance tunes. After i installed the performance tune i no longer had boost, coincidence-maybe, jerry is going to have me send the ecu to him for a stock flash to check there so i can go forward. My specific question has to do with throttle position. The highest my throttle position reads is 58% at wide open throttle. So far i have not found out how to open saved logs if i do a running log over a few miles. I am not computer literate and opening a .csv file is something i cannot do.
My iat's are good and the ic pump is new and working. The sc clutch will engage when hot wired. It seems each individual component works but not in tandem with the others, very frustrating. I bought this car last september and they had to replace the gas pedal assembly then at a cost of $500. To the dealer. I could buy a pedal assembly from partsgeek for under $200. But mine should be working just 4 months after a new one was installed.
Jerry is going to have me send mine back for that stock flash as stated but if it makes no difference i need to figure what is next besides a very costly diagnostic/repair that could be done at half the cost if i knew what part is faulty.
If anyone could tell me what they get when they datalog and what parameters are considered normal i would sure appreciate. It would seem a throttle position of 100% would be normal with the pedal on the floor but i will assume nothing with these cars. By the way i have a 2002 slk32 amg. Thanks, mark
