Old Jan 11, 2015 | 04:26 PM
onehundred80
Default Re: exterior door handle removal EASY 2 screws
Originally Posted by mobilefitt
I just replaced my speakers and hooked the door handle up, the best I could but it's not opening the door from the inside.
Does this DIY fix help me and if so, where is it located. Thanks in advance.
Mobile
Beside clipping the end of the door pull cable into the white clip, the end of the outer cable has to go into a pocket to keep the outer cable in place while the inner cable pulls the lock release. It is just like your ten speed bikes brakes in that regard.
See picture #8 in this PDF.
