Old Jan 18, 2015 | 02:47 PM
JesseJamessrt6's Avatar
JesseJamessrt6
Default Re: parking light comes on with brakes
Thank you guys for your help. I finally got around to looking back into this.
So I also had the side marker lamps all go out at once. The same driver side parking lamp that used to come on with the brakes also went out. The only thing working for parking lamps is the passenger front one. I replaced the ICM, no change, did a voltmeter test, the working front passenger lamp has good voltage but the driver side has only 1.75 using the integrated brown wire ground or me grounding on the body, same voltage. Tested at the back of the ICM and full voltage going to everything. So, somewhere in the wiring between the ICM and the bulb connectors?
frustrating.
